Group: DynoMotion Message: 12130 From: Hardy Family Date: 8/19/2015
Subject: Reboot command not working on 433m
I am attempting to use the "reboot!" script command (from kmotion.exe console) with version 433m firmware.  Although it does seem to halt any threads running on the kflop, it seems to hang the board permanently until I repower it.
I would expect to see the 2 LEDs flash, but it doesn't do that.  Subsequently, kmotion.exe pops up a message box that it "can't connect to kmotion board" whenever I try to issue a console command.
Any help would be appreciated.  The ability to reboot on command will make it easier to upgrade firmware in the field, since we want to automate the process as much as possible.
SJH
Group: DynoMotion Message: 12131 From: Tom Kerekes Date: 8/19/2015
Subject: Re: Reboot command not working on 433m
Hi SJH,
The Reboot! command in prior Versions has never work properly.  But I think we finally found the reason which was regarding the default Flash Page Setting.
Please try this new KFLOP Firmware to see if it works for you.
Also regarding the 2nd MByte of Flash Memory:  Flashing new Firmware should only effect the 1st MByte and not the 2nd.
